11-03-2018 04:16 AM - edited 07-05-2021 09:24 AM
I have 2 7500 WLC’s configured in SSO/HA.
The redundancy port of both WLC's is connecting to a L2 switch which I have to replace.
My question is can I just replace the switch without any issues or will I get a split brain meaning both wlc's will be active.
What is the best solution to do this change without any interruptions?
Solved! Go to Solution.
11-03-2018 08:56 AM
If your concerns only HA port connected switch.
if it is active standby - Shutdown one of the WLC in HA, prefer shutdown secondary since primary already serving the requests.
replace the switch.
If active / Active, Fail over all AP to one Controller, and shutdown other one. replace switch and bring back and load balance the AP association back to both.
Make sense ?
11-03-2018 08:56 AM
replace the switch.
Make sense ?
11-03-2018 10:08 AM
Thanks for the input the WLC's are in active-standby. I think the best would be to shutdown the standby WLC and do the switch replacement. On the specific switch only the redundancy ports are connected to this switch.
What would happen if I just replace the switch would both WLC’s become active?
11-03-2018 10:13 AM
