Highlighted
Beginner
WLC integration with Microsoft AD
Dear All,
I want to Integrate Cisco WLC with Microsoft AD. I have got one documentation form Cisco Site , but it is not working.
Can any one please provide me any link or configuration documentation ?
Design :
user will get the IP address from WLC when the username and password gets velidated from existing Microsoft AD.
Arindam
6 REPLIES 6
Highlighted
I assume you want to use local EAP against Microsoft AD.
As I know WLC can only work with a LDAP database but not Microsoft AD.
Refer to this document:
LEAP, EAP-FAST/MSCHAPv2, and PEAPv0/MSCHAPv2 are also supported,       but only if the LDAP server is set up to return a clear-text       password. For example, Microsoft Active Directory is not supported       because it does not return a clear-text password. If the LDAP server cannot be       configured to return a clear-text password, LEAP, EAP-FAST/MSCHAPv2, and       PEAPv0/MSCHAPv2 are not supported.
http://www.cisco.com/en/US/partner/products/ps6366/products_configuration_example09186a008093f1b9.shtml#backinfo
Best regards.
Highlighted
oops sorry!!!!
Its....  Nice point Raul !!!
Surendra
Surendra BG
Highlighted
Nice point Arindam!!
Any RADIUS server in the middle will help you a lot to communicate with the AD.. so that u can use most of the things.. if not.. use LOCAL EAP-FAST..
Surendra
Surendra BG
Highlighted
Microsoft AD supported or not is the answer?
Highlighted
We cannot integrade AD directly without ACS (Radius) to the WLC.. there is only one option. that is to go for LDAP and The link posted by Raul in the begining of the thread will let us know the limitations..
Let me know how this answers your question.
Surendra
Surendra BG
Highlighted
In clear, integrating the WLC with the AD as LDAP database will limit you to the methods not containing "mschapv2". For example : peap-gtc, eap-fast-gtc and eap-tls.
Nicolas
