319
Beginner
WLC login issue
I have  a AIR-CT2504-K9 WLC running 8.0.133.0 version. I was using local credentials to login to it.
But now, After entering TACACS authentication details, I changed the priority order on the WLC with first as tacacs and then local. On the TACACS server, by mistake the WLC details was not entered correctly.
Now, I am unable to login through local and tacacs aswell.
Could someone suggest any troubleshoot here?
Everyone's tags (1)
12 REPLIES 12
Re: WLC login issue
If you haven’t saved the configuration of the WLC post these changes. Take a reboot of it (power cycle).
Also whats the wrong information entered on the TACACS?
Since its on TACACS, you can correct it on the TACACS.
Sathiyanarayanan Ravindran
Please rate the post and accept as solution, if my response satisfied your question:)
Beginner
Re: WLC login issue
Any other options other than reboot?
Also I tried changing on the TACACS server, But no luck. Looks like I need to enter the tacacs details again on the WLC?
Any other solution here?
Re: WLC login issue
If TACACS is still not working, what is the error you are getting on the TACACS logs.?
Re: WLC login issue
Take console of the WLC and login to it via local username and password.
Beginner
Re: WLC login issue
Will it work if I enter local credentials on console? I don't think so.
Re: WLC login issue
Remove the WLC ip from the tacacs. So that tacacs will get failed nd the local should start to work
Beginner
Re: WLC login issue
Already  removed the wlc entry form tacacs. no luck
Collaborator
Re: WLC login issue
If you cannot get into your wlc, then the last option would be to reset the controller to default setting. You will need to reconfigure the controller from scratch.
To reset controller to default settings, follow the doc below:
https://www.cisco.com/c/en/us/td/docs/wireless/controller/8-0/configuration-guide/b_cg80/b_cg80_chapter_0110.html
John
**Please rate posts you find helpful**
Contributor
Re: WLC login issue
Try accessing through service port, you are not clear on what mistake you did on TACACS+ server ?
-Rate helpful posts-
Highlighted
Beginner
Re: WLC login issue
Yes. I am not sure what mistake was done on TACACS and WLC. I tried to remove the tacacs entry and readded again. Still no luck. Looks like I had a mistake done on WLC itself.
So Can i use Service port login using local credentials to work?
VIP Engager
Re: WLC login issue
If you are lucky, yes. Otherwise you need to reset to factory defaults (if you have saved the configuration).
Contributor
Re: WLC login issue
is there a way you can shutdown TACACS server or make it unreachable from WLC, till the time TACACS is reachable your local credential won't work based on how you have described the setting.
Service port has default IP of 192.168.1.1 unless you changed it during initial configuration, you can connect to service port with a laptop assign yourself an IP 192.168.1.2/24, try pinging it and try GUI.
Content for Community-Ad
July's Community Spotlight Awards
