02-18-2019 04:33 AM - edited 07-05-2021 09:53 AM
Hi together,
i have a WLC with 8.5. Is there a guide, how to implement the LSC Device Certificate? Do i really Need this certificate? In 8.0 there is no Option for the Device Certificate, only CA.
Many thanks
Gordon
02-18-2019 07:15 AM
You definitely don´t need Locally Significant Certificate (LSC). Unless you intend to mange the certificate that is distributed to your APs.
If you are referring to a SSID with EAP-TLS, all you need is a certificate installed on your RADIUS server and provisioned on your devices using some kind of MDM. The WLC itself will not play any role on this process as it accepts any kind of EAP method.
-If I helped you somehow, please, rate it as useful.-
02-18-2019 08:28 AM
02-18-2019 09:35 AM
I recommend this document:
02-18-2019 10:54 AM
02-25-2019 02:16 AM
Has someone an idea?
