Community Live- Understanding How Multicast Works with Cisco
231
Highlighted
Beginner
WLC Mobility Group "Control and Data Path Down" Guest and LAN controller
Dear Guys,
Currently i am building a WLC setup , where i setup two WLC in active / standby configuration. Currently i am using version  7.4.121.0 on all three controller. two for LAN and one is guest controller.
Active / Standy work fine But i am not able to see the mobility group work as it show " Control and Data Path Down"
i try to reboot the controller multiple time but still no success.  Any body help will be appreciated
LAN controller can ping to Guest controller.
Following is the output from LAN controllers.
For Active / Standy   some output .. like Redudancy , ping and mobility summary
(Cisco Controller) >show redundancy summary
 Redundancy Mode = SSO ENABLED
     Local State = ACTIVE
      Peer State = STANDBY HOT
            Unit = Primary
         Unit ID = 18:E7:28:C0:57:00
Redundancy State = AP SSO
    Mobility MAC = 18:E7:28:C0:57:00
Average Redundancy Peer    Reachability Latency = 960 usecs
Average Management Gateway Reachability Latency = 676 usecs
Redundancy Management IP Address................. 10.23.120.13
Peer Redundancy Management IP Address............ 10.23.120.11
Redundancy Port IP Address....................... 169.254.120.13
Peer Redundancy Port IP Address.................. 169.254.120.11
Peer Service Port IP Address..................... 0.0.0.0
(Cisco Controller) >ping 10.23.120.12
Send count=3, Receive count=3 from 10.23.120.12
(Cisco Controller) >ping 10.23.120.50
Send count=3, Receive count=3 from 10.23.120.50
(Cisco Controller) >show mobility summary
Mobility Architecture ........................... Flat
Mobility Protocol Port........................... 16666
Default Mobility Domain.......................... GH-WLC-Wifi
Multicast Mode .................................. Disabled
Mobility Domain ID for 802.11r................... 0x52ef
Mobility Keepalive Interval...................... 10
Mobility Keepalive Count......................... 3
Mobility Group Members Configured................ 2
Mobility Control Message DSCP Value.............. 0
Controllers configured in the Mobility Group
 MAC Address        IP Address       Group Name                        Multicast IP     Status
 18:e7:28:c0:57:00  10.23.120.12     GH-WLC-Wifi                       0.0.0.0          Up
 74:a2:e6:c6:89:20  10.23.120.50     GH-WLC-Wifi                       0.0.0.0          Control and Data Path Down
Guest WLC output for mobility ( note Guest controller mangment IP can able to reach LAN controller "
Default Mobility Domain.......................... Guest-Wifi
Mobility Domain ID for 802.11r................... 0x91d7
 18:e7:28:c0:57:00  10.23.120.12     Guest-Wifi                        0.0.0.0          Control and Data Path Down
 74:a2:e6:c6:89:20  10.23.120.50     Guest-Wifi                        0.0.0.0          Up
Content for Community-Ad
August's Community Spotlight Awards
