WLC Public Certificates
Richard Strnad
Level 4
Level 4
Hi All,
Is there any possibility to generate/export public certificates from a WLC 5508? Our Customer would like to backup his configuration through certificated based authentication instead of user based.
I believe there is no way to do that, but still i would like to ask the community
Richard
Sandeep Choudhary
HI,
As per my knowledge: No you can't, By default, WLCs use a built-in self-signed SSL certificate.
If you want use 3rd party certificate then check this link:
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wlan-security/70584-csr-wlc-00.html
Dont forget to rate helpful posts
Sandeep Choudhary
HI,
#TCN
is this still the case with 8.x? - looking to backup / export existing SSL certificate, i have a new one that is ready to be uploaded for the Guest wireless.
I'm guessing a config backup would do the job?
