WLC sofware upgrdae issue
shazeb051
we are having cisco 2504 wlc and 2602I access points .. and wlc having 7.0.220.0 Software version which is not supporting access points.. i configure wlc and app not registering in order to upgrade softer which supports 2602I which software shell i chose
next issues is.  unable to download and upload file from controller.
1.cisco wlc 2504 tftp code file type not supported!
2.% error: license file file transfer failed - no reply from the tftp server.
getting this error even after connected laptop directly to wlc also and on connected network also.
3 Accepted Solutions
Sandeep Choudhary
2602 AP require min version of 7.2.100.0 and newer.
so you need to upgrade the WLC ftom 7.0 to 7.2 or higer.
Regarding issues:
1. you are uploading wrong files
Dont forget to rate helpful posts
Sandeep Choudhary
if you newer AP models then you nee dto upgrade further.
upgrade path:
First you need to upgrade from 7.0 to 7.4 version
then upgrade to 7.4 to 8.0
8.0 to 8.3
and last 8.3 to 8.5
yes its recommanded to use FUS version 1.9 or higher if you want to use 8.3. higher version software on WLC.
Sandeep Choudhary
Regarding issues:
Sandeep Choudhary
upgrade path:
8.0 to 8.3
and last 8.3 to 8.5
Thanks.
Is FUS also mandatory to install or not ?
