05-20-2019 04:06 AM - edited 07-05-2021 10:26 AM
we are having cisco 2504 wlc and 2602I access points .. and wlc having 7.0.220.0 Software version which is not supporting access points.. i configure wlc and app not registering in order to upgrade softer which supports 2602I which software shell i chose
next issues is. unable to download and upload file from controller.
1.cisco wlc 2504 tftp code file type not supported!
2.% error: license file file transfer failed - no reply from the tftp server.
getting this error even after connected laptop directly to wlc also and on connected network also.
Solved! Go to Solution.
05-20-2019 04:08 AM
2602 AP require min version of 7.2.100.0 and newer.
so you need to upgrade the WLC ftom 7.0 to 7.2 or higer.
Regarding issues:
1. you are uploading wrong files
Dont forget to rate helpful posts
05-20-2019 04:10 AM
if you newer AP models then you nee dto upgrade further.
upgrade path:
First you need to upgrade from 7.0 to 7.4 version
then upgrade to 7.4 to 8.0
8.0 to 8.3
and last 8.3 to 8.5
05-20-2019 05:06 AM
yes its recommanded to use FUS version 1.9 or higher if you want to use 8.3. higher version software on WLC.
05-20-2019 04:08 AM
Regarding issues:
05-20-2019 04:10 AM
upgrade path:
8.0 to 8.3
and last 8.3 to 8.5
05-20-2019 05:05 AM
Thanks.
Is FUS also mandatory to install or not ?
05-20-2019 05:06 AM
