02-10-2020 04:37 AM - edited 07-05-2021 11:40 AM
We are trying API based login using app in WLC8500 but facing issue i.e. if the user doesn't triggers webauth session the login process doesn't flows due to error. The process only flows when captive portal at user end triggers. The whole point of using app is that captive portal doesn't triggers and user experience is better. Can someone suggest what we may be doing wrong and how we can rectify this?
cheers
02-11-2020 06:34 AM
02-11-2020 08:34 AM
rrudling,
Thanks for your reply. The OS we are trying on is Android.
I understand that this is more related to Software Development rather than wireless. When you say API/app level captive portal redirect what do you mean by it, have you ever done this?
02-11-2020 09:34 AM
