05-27-2020 01:11 AM - edited 07-05-2021 12:06 PM
New weird issue with the 9800-80 and AP9130. I have about 10 APs up on one edge-switch. 3 of these have joined the WLC and are working as expected. However, the last 7 are nowhere to be seen, even though they have the same DHCP-server (with the same option 43). Cant really see much of what's going on in the 9800-logs either. All 10 APs are reachable from controller with ping, but a debug ip packet on the WLC shows no attempts to join. Their image download has not started either, but why would 7 out of 10 APs not download the image? The troubleshooting part from https://www.ciscolive.com/c/dam/r/ciscolive/apjc/docs/2019/pdf/BRKEWN-3081.pdf yielded little results. Any ideas?
Software on 9800-80 17.2.1.
Smart licensing enabled:
AP Perpetual Networkstack Advantage (DNA_NWStack):
Description: AP Perpetual Network Stack entitled with DNA-A
Count: 3
Version: 1.0
Status: AUTHORIZED
Export status: NOT RESTRICTED
Was thinking this might be a license issue, but we have thousands of available licenses.
From CDP its clear that the image part is wrong, but they never start their download:
Cisco AP Software, ap1g6a-k9w8 Version: 17.2.1.11 <- working
Cisco AP Software, ap1g6a-k9w8 Version: 8.10.105.0 <- not working
05-27-2020 03:29 AM
- Attach a console to the problematic ap's (or one of them) and follow the complete boot process preferably also through a manner where the boot-log can be kept and reviewed - watch for errors and or concerning the join process.
M.
05-27-2020 05:49 AM
I would check if one of those AP put on the same vlan as WLC management, would it register using local vlan broadcast method?
Rasika
05-27-2020 06:49 AM
05-28-2020 01:26 AM
From console output I see the AP (c9130) connected to a Meraki switch is constantly sending CAPWAP discovery:
Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0).
The weird thing is that the AP is not processing any other method to populate the list of the known controllers but local broadcast (not DHCP option 43 currently configured, no DNS currently configured, not anything)
From Meraki's pcap file I see the CAPWAP discovery packet is malformed. Maybe this is due to the lack of destination in the packet.
Control And Provisioning of Wireless Access Points - Control
[Malformed Packet: CAPWAP-CONTROL]
[Expert Info (Error/Malformed): Malformed Packet (Exception occurred)]
[Malformed Packet (Exception occurred)]
[Severity level: Error]
[Group: Malformed]
this is first time I connect c9130 so maybe is some bug included on manufactured release code (8.10.105.0). Checked both release notes for this and later codes, and Cisco Bug Search Tool, but nothing there in regards of this as a known bug.
I'm going to open a TAC case becuase of this.
-Jesus
*** Please Rate Helpful Responses ***
05-28-2020 03:42 AM
- I wonder -> do they work when connected to a native cisco switch ?
M.
05-28-2020 04:03 AM
05-27-2020 07:07 AM
