Community Helping Community
1382
Enthusiast
WLCCA 4.1(6) - 30037,General: Non default RRM timer in use (CHA)
Hello
I just run WLCCA against a WLC running 8.0.121.0
I got the following errors:
30037,General: Non default RRM timer in use. This is not recommended unless directed by Cisco support. Coverage Hole Interval 11a:90
30037,General: Non default RRM timer in use. This is not recommended unless directed by Cisco support. Coverage Hole Interval 11b:90
But regarding this RRM Whitepaper 90s is the default timer for.
Am I right?
Markus
1 ACCEPTED SOLUTION
BTW, beta version of 4.22 is
BTW, beta version of 4.22 is now available with the fix, in case you want to give it a try
4 REPLIES 4
hi Markus
hi Markus
yes!
just checked on WLC code, on 7.x it was 180, but on 8.x it was updated to 90 sec, as part of improvements done on RRM calculations
I will modify the value on WLCCA for upcoming 4.2 release, thanks for reporting
regards
Highlighted
Enthusiast
Hi Javier
Hi Javier
The beta of 4.22 fixed this.
good, thanks for confirming!
Content for Community-Ad
August's Community Spotlight Awards
