04-15-2016 05:11 AM - edited 07-05-2021 04:54 AM
Hello
I just run WLCCA against a WLC running 8.0.121.0
I got the following errors:
30037,General: Non default RRM timer in use. This is not recommended unless directed by Cisco support. Coverage Hole Interval 11a:90
30037,General: Non default RRM timer in use. This is not recommended unless directed by Cisco support. Coverage Hole Interval 11b:90
But regarding this RRM Whitepaper 90s is the default timer for.
Am I right?
Markus
Solved! Go to Solution.
04-16-2016 12:37 AM
BTW, beta version of 4.22 is now available with the fix, in case you want to give it a try
04-15-2016 08:50 AM
hi Markus
yes!
just checked on WLC code, on 7.x it was 180, but on 8.x it was updated to 90 sec, as part of improvements done on RRM calculations
I will modify the value on WLCCA for upcoming 4.2 release, thanks for reporting
regards
04-16-2016 12:37 AM
04-21-2016 01:56 AM
Hi Javier
The beta of 4.22 fixed this.
04-21-2016 03:36 AM
good, thanks for confirming!
