03-26-2019 06:01 AM - edited 07-05-2021 10:08 AM
We are looking to implement WPA2 Enterprise for Managed Mobile Devices such as iPhone 6 and above. Currently they are using WPA2 Personal.
This is a part of Guest users and traffic for this WLAN is anchored to the anchor WLC(Model:5508 version 8.0.152.0 and 3504 version 8.5)
Do we have any cisco recommended advise or the security benefits detailing security shortfall of current WLAN with security protocol WPA2 Personal being used and benefits to securing the WLAN using WPA enterprise.
03-26-2019 06:21 AM
03-28-2019 01:30 AM
ok.
So how do I check the compatibility of using WPA2 enterprise on the mobile devices and its compatibility with the AP models and WLC IOS version
03-28-2019 01:41 AM
You need to research the device compatibly to first understand what security method you can use. As far as any wireless solution, majority of aps/controllers support WPA2. This can be found in the data sheet for any vendors products. Know your devices, then you will know what is possible and what is not.
