Not all configuration items shows up using the Cisco-IOS-XE-native YANG module
Hi all,
I am trying to accomplish a task of retrieving the full running configuration using RESTCONF running on a CSR IOS-XE 16.6, i've tried multiple yang models and the only one that appears to retrieve the configuration is Cisco-IOS-XE-native, however, configurations such route-maps are not showing up in the tree retrieved using the native container.
Could someone share some tips or suggestions? i am sort of new to yang and restconf so i am pretty sure i might be missing something.
Thanks in advance!
Ok so it turned out that the OS version i was using 16.6 was the only that was not returning all the configuration objects. Issue resolved after downloading the CSR v16.11.01b.
