Beginner
Cisco Ip Camera 2500 Audio Can't be enabled.
Dear all,
My 2500 IP Camera when i press on the audio check mark to enable it and then press save then i just go from the audio page to the video page and get back to the audio page the enable mark that i did check and save a sec ago is not there.
it happened with the 2500 only after the upgrade of the operations manager from 6.XX to other 6.XX not a major upgrade, this upgrade was because there was a problem for windows 7 and it was runnning on windows xp only. but this is not the issue after the upgrade my 4500 and 2611 Cameras working fine and audio is selected and have no problem with it, the only thing i am trying to fiqure it our is the audio for the 2500 Camera.
Thanks and appreciate your help.
