01-06-2021 03:37 AM
I would like to know if a device in general or a firewall in particular has the ability to provide me with graphics and other monitoring information in real time via its web management interface.
01-06-2021 03:39 AM - edited 01-06-2021 03:40 AM
Depends on what Firewall you have, in general cisco concern.
ASA - has tool called ASDM which uses to configure
FTD - uses FMC /. FDM - these new you can have GUI to configure.
Apart from that both support REST API can configure from other interfaces to interact with this device.
01-06-2021 04:05 AM
Thank you for the answer. I'd like to know if like all switches or routers, firewalls can show basic graphics (CPU, port status, etc.) on the web interface?
01-06-2021 04:12 AM
yes, best way if you looking to monitor device is NMS using SNMP.
