01-19-2016 03:21 PM
I am trying to setup the Cisco PTZ camera to return to a designated home position after a period of inactivity. For example, a guard is using a PTZ to follow someone and they switch cameras. After 5 mins or so, I'd like the first camera to return to it's designated view. Is this possible, and can anyone provide some direction? Thanks in advance, much appreciated.
01-27-2016 06:38 AM
It sure is. What version of VSM are you using?
I don't have a functional PTZ at the moment to show you, but under the PTZ configuration UI in VSOM, there is an "Advanced Settings" button that should allow you to set a 'Home' preset and defined 'rollback' time.
Hope this helps.
Cheers!
01-27-2016 08:15 AM
Thanks so much for the reply!
We are using 7.5.1, I don't seem to have the same tabs as you do, I attached the screenshot below. I am logged in as an admin, and this is a PTZ camera. Which version are you using? Thanks again, I appreciate the reply!!
01-27-2016 10:24 AM
:-( I believe it's only been added in VSM 7.6 and onward :-S. There *may* be a way to schedule a workaround to make a 'scheduled preset' happen in 7.5, but its pretty kludgy.
01-27-2016 11:42 AM
Thanks again for your help, much appreciated!!
