05-23-2011 01:20 PM
Has anyone went through the process of mounting the 5011 hd camera in the Pelco Outdoor Housing DF5-PG-E1? We cannot figure it out and can't seem to see any logical way it will work. Any help would be beneficial.
Solved! Go to Solution.
06-09-2011 08:06 AM
Zack,
It's not as fun and easy as it sounds, but the 5000 series cameras do fit into the DF5 housings, but you need an ID-DF5 adapter that replaces the L shaped bracket in the housing.
When you go to install the camera into the housing make sure the Heater/blower resides on top of the cameras plastic surround. The surround pushes slightly against the H/B but it makes a good fit. Also, I have had better luck by screwing down one side and then the other into the ID-DF5 bracket clips.
Hope this helps.
06-08-2011 04:05 PM
Hi Zack,
I see that this question remains unanswered. Were you able to mount the 5011 in the DF5-PG-E1 Pelco housing? I have posted internally to ask field support, TAC and PSBU if we have anyone with hands on experience mounting in that particular housing.
Jim
06-09-2011 08:06 AM
Zack,
Hope this helps.
06-13-2011 11:44 AM
I was able to get a document from cisco that was able to use the additional bracket and convert it to be able to use.
06-13-2011 12:13 PM
Thanks for the update, Zack. I'm glad you were able to work through the install.
I just published a document (with permission of the author, Shailesh Deshmukh) which details mounting instructions complete with pictures. Hopefully this doc will answer future questions about installing a Cisco 5000 series camera in an outdoor mount.
