I am running Vista (32 bit) on a laptop and IE7. The LAN port is configured to 192.168.1.10 & subnet mask is 255.255.255.0.
When I bring up IE and enter 192.168.1.42, I get a login page, login works ok, but the Image Management tab does not show any installed images.
The gateway does not appear to be talking to the pc. I need to pre-install new images prior to physical install.
PLAESE HELP!
