IP Camera 4300 upgrade firmware
hisham.khreisat
Dears,
When I tried to upgrade the 4300 Cameras from 1.0.1 to 1.2.1, I opened the GUI of the CAM SETUP>>Administration>>Firmware>>> then when I upload the image and click upgrade, I got a message "ActiveX initialization failed", I tried to make it on IE8, Google Chrome, and FireFox. and I got same message on all these browers.
If anyone has an idea about a solution for this tell me please.
Also you can upgrade it direcly if you  are using version 6.3.0 or 6.3.1 , from VSMC you will find the path to upgrade Cisco IP cameras.
Ahmed Ellboudy
John Gillich
In your internet explorer go to Tools>options>security>Custom and allow all active X options. Due the upgrade then reset the security options back to default.
Ahmed Ellboudy
James Sullivan
Hi Hisham,
I have seen this active x message when upgrading in the past.  Please try adding the camera URL http:// as a trusted site under IE Tools -> Internet Options -> Secturity -> Local Intranet.
If this has answered your question, please mark the question as answered.
Thank you,
Jim
hisham.khreisat
I tried the first two steps didn't work, so I will try to do the last one
