playback speed
Danny Mainprize
Before upgrading to 6.3.2 I was able to adjust the playback speed while watching archive clips.  Now the speed bar changes but it does not change the playback speed.  Anyone else seen this or have any idea how to correct this?  I am about to upgrade to 6.3.2-MR2, but I don't have high hopes of correcting this issue with that.
Forgot to mention.  I am running on Windows 7 x64 and IE9 if that makes any difference.  Doesn't work in XP either.
Scott Donahue
Danny,
Checkout this thread... https://supportforums.cisco.com/message/3754463#3754463
Karen Capoor gives a link to a microsoft update that is causing the issue and a fix.  It worked for me.
This can be found in https://supportforums.cisco.com/message/3754463#3754463 thread.  Credit and thanks go out to Karen Capoor...
Try the procedure below and you will get the scroll bar working again.
As soon as Update KB2597986 is applied to any machine VSOM will no longer allow you to fast forward or rewind archived video.
This update closes a fairly significant hole in Office 2010 and once applied it cannot be uninstalled.
This update causes issue with ActiveX
Workaround:
To resolve the issues the Windows Update causes to ActiveX:
http://support.microsoft.com/kb/2597986
Scroll towards the bottom of the page till you find the "fix it" button
Running the Fix It program
Restart IE
log back into VSOM
scroll bar and speed slier should both be fixed
let me know if this help
thanks
Karan capoor
Scott
Scott Donahue
Danny,
Workaround:
Restart IE
log back into VSOM
thanks
Karan capoor
Scott
