Possible to connect 7.9 VSMS to 7.8 VSOM?
jwood.ok
Our infrasturcture is currently 7.8.  We got a new server that has 7.9 on it.  Is it possible to connect a 7.9 media server to a 7.8 VSOM server, or would the media server need to be downgraded to 7.8?
Adam S
Hi John
Nope, is not possible. You'll see version error.
Also, there is no option do downgrade the VSM software.
You need to reinstall software using 7.8 recovery image with 'factory' option
Hi Adam, thanks for the reply.  I actually ended up opening a TAC case.  I was afraid that i'd have to recover all the way back to 7.7 and then upgrade to 7.8 but the technician was able to use the 7.8 upgrade files after uninstalling the 7.9 rpms.  Works great now.
