03-25-2011 08:30 AM
Does anyone have issues upgrading the 2500 series cameras from the VSMC? Upgrading the 4500s performs seamlesly but I am getting the following message when try to upgrade the 2500s.
2011-03-25 10:06:12.705 Starting upgrade for 1 cameras.
2011-03-25 10:06:12.705 Current status 2 (Preparing for upgrade).
2011-03-25 10:06:12.705 Camera 192.168.37.51 - Added to update queue.
2011-03-25 10:06:12.706 Current status 3 (Loading upgrade file).
2011-03-25 10:06:12.854 Read 33554432 byte upgrade file (/usr/BWhttpd/root/htdocs/uploads/Ouvrir-V2.1.7R00.bin).
2011-03-25 10:06:12.854 Current status 4 (Successfully loaded upgrade file).
2011-03-25 10:06:12.854 Current status 9 (Installing upgrade file on cameras).
2011-03-25 10:06:12.854 Camera 192.168.37.51 - Upgrade started.
2011-03-25 10:06:33.811 Camera 192.168.37.51 - Uploading firmware to camera.
2011-03-25 10:07:48.894 Camera 192.168.37.51 - ERROR: Upgrade failed.
2011-03-25 10:07:48.894 Current status 11 (Camera firmware upgrade process ended).
2011-03-25 10:07:48.894 Exit status 12 (Failed to upload firmware to camera).
Status summary:
Current status code: 11 (Camera firmware upgrade process ended)
Current exit code: 12 (Failed to upload firmware to camera)
Total cameras in upgrade: 1
Completed cameras in upgrade: 0
Failed cameras in upgrade: 1
Remaining cameras: 0
ERROR: Upgrade finished without upgrading any cameras
Solved! Go to Solution.
03-25-2011 03:21 PM
Mothership says:
Do not extract the image. Simply use the CIVS-IPC-2XXX-V2.1.7.bin.gz file that you downloaded from Cisco.com to perform the upgrade.
2011-03-25 18:10:23.788 Starting upgrade for 1 cameras.
2011-03-25 18:10:23.788 Current status 2 (Preparing for upgrade).
2011-03-25 18:10:23.789 Camera 10.114.1.4 - Added to update queue.
2011-03-25 18:10:23.789 Current status 3 (Loading upgrade file).
2011-03-25 18:10:23.801 Read 10462459 byte upgrade file (/usr/BWhttpd/root/htdocs/uploads/CIVS-IPC-2XXX-V2.1.7.bin.gz).
2011-03-25 18:10:23.802 Current status 4 (Successfully loaded upgrade file).
2011-03-25 18:10:23.802 Current status 9 (Installing upgrade file on cameras).
2011-03-25 18:10:23.803 Camera 10.114.1.4 - Upgrade started.
2011-03-25 18:10:44.698 Camera 10.114.1.4 - Uploading firmware to camera.
2011-03-25 18:11:31.571 Camera 10.114.1.4 - Uploading firmware to camera successful.
2011-03-25 18:12:01.573 Camera 10.114.1.4 - Waiting for the camera to come online
2011-03-25 18:17:47.257 Camera 10.114.1.4 - Upgrade completed successfully (new version: 2.1.7).
2011-03-25 18:17:47.259 Current status 11 (Camera firmware upgrade process ended).
2011-03-25 18:17:47.259 Exit status 0 (Camera firmware upgrade ended without any fatal errors).
Status summary:
Current exit code: 0 (Camera firmware upgrade ended without any fatal errors)
Completed cameras in upgrade: 1
Failed cameras in upgrade: 0
If this resolves your issue, please mark the question as answered.
Thank you,
Sean
03-25-2011 02:48 PM
What firmware version are the 2500s on now?
03-25-2011 02:51 PM
2.1.6.
03-25-2011 02:53 PM
D'oh! It should work then. Let's see what the mothership comes back with.
03-25-2011 03:21 PM
Mothership says:
Status summary:
Thank you,
Sean
03-25-2011 06:09 PM
Works like a charm. Thank you Sean.
Please see a question a posted under the Mass move of Cameras from one media server to another in VSM 6.2.0 post. I have a question about migrating user accounts between servers not linked via a network.
04-16-2011 05:21 PM
Hi Ainsley,
I'm glad Sean could resolve your issue. Please be aware that there are 2 enhancement requests I filed to prevent others from having similar problems with the VSMC camera upgrade process.
CSCti31580 - Require validation for VSMC Camera Firmware Upgrade Image. (Code the utility to perform a file check at least of the file suffix before attempting the upgrade)
CSCti31614 - VSM 6.3 Install Guide should list .gz as the file type for camera fw upgrade
Please pass the word. I know it's a bit confusing since upgrading the 25xx series cameras through their web interface requires using the extracted .bin, while the VSMC upgrade utility uses the compressed .gz file (which contains the .bin)
Jim
04-17-2011 03:00 PM
Thanks for the follow up Jim. I'll pass it on.
