01-10-2014 10:24 AM
Hello all!
I was wondering if someone can post the commands to check a drive rebuild status for VSOM 6.3.3. I can see it via the WebIOS but need to check remotely. This is on an MSP series server running Linux.
Solved! Go to Solution.
01-10-2014 12:37 PM
/opt/MegaRAID/MegaCli/MegaCli -pdrbld -showprog -physdrv "[
... likely.
Others are:
Info on the raid (assuming the raid is a0)
/opt/MegaRAID/MegaCli/MegaCli -ldinfo -lall -a0
/opt/MegaRAID/MegaCli/MegaCli -pdlist -a0
The file MegaSAS.log from the current directory will also contain the output of the commands,
To start the rebuild of drive 0, run the command (only if it didn't start on its own), this makes the drive a hot spare:
/opt/MegaRAID/MegaCli/MegaCli -pdrbld -start -physdrv "[
If a drive gets marked as "foreign", clear the foreign configuration:
/opt/MegaRAID/MegaCli/MegaCli -CfgForeign -Clear -a0
And, to silence the beeping:
/opt/MegaRAID/MegaCli/MegaCli -adpsetprop AlarmSilence -aALL
Flash start / stop
/opt/MegaRAID/MegaCli/MegaCli -pdlocate start physdrv [8:1] -a0 -nolog
/opt/MegaRAID/MegaCli/MegaCli -pdlocate stop physdrv [8:1] -a0 -nolog
Hope this helps!!
Scott Olsen
Solutions Specialist
Bulletproof Solutions Inc.
Web: www.bulletproofsi.com
01-10-2014 12:37 PM
... likely.
Others are:
Flash start / stop
Hope this helps!!
Scott Olsen
01-13-2014 08:06 AM
Thats what I needed. Thank you!
