VSOM 6.3.3 Drive Rebuild
DAvelarNIC
Beginner
Beginner
Hello all!
I was wondering if someone can post the commands to check a drive rebuild status for VSOM 6.3.3. I can see it via the WebIOS but need to check remotely. This is on an MSP series server running Linux.
Scott Olsen
Frequent Contributor
/opt/MegaRAID/MegaCli/MegaCli -pdrbld -showprog -physdrv "[:]" -a0
... likely.
Others are:
Info on the raid (assuming the raid is a0)
/opt/MegaRAID/MegaCli/MegaCli -ldinfo -lall -a0
/opt/MegaRAID/MegaCli/MegaCli -pdlist -a0
The file MegaSAS.log from the current directory will also contain the output of the commands,
To start the rebuild of drive 0, run the command (only if it didn't start on its own), this makes the drive a hot spare:
/opt/MegaRAID/MegaCli/MegaCli -pdrbld -start -physdrv "[:]" -a0
If a drive gets marked as "foreign", clear the foreign configuration:
/opt/MegaRAID/MegaCli/MegaCli -CfgForeign -Clear -a0
And, to silence the beeping:
/opt/MegaRAID/MegaCli/MegaCli -adpsetprop AlarmSilence -aALL
Flash start / stop
/opt/MegaRAID/MegaCli/MegaCli -pdlocate start physdrv [8:1] -a0 -nolog
/opt/MegaRAID/MegaCli/MegaCli -pdlocate stop physdrv [8:1] -a0 -nolog
Hope this helps!!
Scott Olsen
Solutions Specialist
Bulletproof Solutions Inc.
Web: www.bulletproofsi.com
Scott Olsen Solutions Specialist Bulletproof Solutions Inc. Web: www.bulletproofsi.com
Scott Olsen
... likely.
Others are:
Flash start / stop
Hope this helps!!
Scott Olsen
Thats what I needed. Thank you!
Recognize Your Peers
