ā03-03-2014 07:40 AM - edited ā03-10-2019 09:28 PM
We are about to start a project that shall secure an organisations wired network.
This organisation has 40k clients and around 250k network attached devices (clients, printers, cams, medical equipment, environmental equipment ...)
There are about 3000 Cisco switches connecting the clients.
802.1x and Cisco ISE are used for the wireless network (10k clients).
Is Cisco ISE the way to go for the wired network as well? Does it scale?
Things to think about when designing the solution?
/Jorgen
ā03-03-2014 10:12 AM
ISE 1.2 can suport up to 250,000 conrurrent endpoints.
http://www.cisco.com/c/en/us/td/docs/security/ise/1-2/release_notes/ise12_rn.html
With that being said, you will have to use multiple PSN nodes in a distributed deployment.
**Thank you for rating helpful posts**
Please check the following link:
ā03-12-2014 10:11 PM
System Scale (Per Identity Services Engine deployment)
Description | Number |
Maximum number of NADs | 30,000 |
Maximum number of Network Device Groups | 100 |
Maximum number of Internal users | 25,000 |
Maximum number of Internal guests | 50,000 (Total number of guest account per year is 1,000,000 as accounts get purged) |
Maximum number of EndPoints | 1,000,000 |
Maximum number of Authentication Rules | 25 when Simple mode is used 100 combined rules when Policy Set mode is used |
Maximum number of Authorization Rules | 600 (Best Practice to keep it below 100. With 100+ rules rendering of GUI and user access will be negatively impacted.) |
TrustSec Security Group Tags (SGT) | 4,000 |
TrustSec Security Group ACLs (SGACLs) | 2,500 |
