AAA failures on 3750G running ADVIPServ 12.2(53) SE
karim.rahemat
I am just banging my head on the wall and I can seem to figure it out.  I am trying to configure my 3750G stack to authenticate to my ACS 4.2 server.  The configuration is fine and when I look at the debugs I am getting from the switch that it selected the default profile and that is the extent of the log.  On the server I am getting a failed authentication of invalid secret key.  I have a multiple times changed the secret key to match and still getting the same issue.  I thought that it was because the source interface being a L3 port-channel and changed it to a vlan interface with the same issue.
aaa new-model
aaa authentication login default group tacacs+ local
aaa authentication login noauth local
aaa authorization exec default group tacacs+ local
aaa authorization exec noauth local
aaa authorization console
ip tacacs source interface port-channel 1
tacacs-server timeout 5
tacacs-server host 10.224.1.181
tacacs-server key itsasecret
tacacs-server directed-request **must be a default command**
line con 0
login authentication noauth
line vty 0 15
login authentication default
Any help would be appreciated as I don't know if I am hitting a bug or not and searches have turned up nothing.
Karim
Jennifer Halim
On ACS server, please check that you do not have a different secret key under NDG (Network Device Group) which is the likelihood of the error message that you are getting with regards to invalid secret key.
I looked into that and deleted whatever key was in there and made sure teh client had a proper key.  This gave me the same error so I deleted client to try again with the same results.  I also deleted the NDG and recreated a new one with no success.  Still getting the invalid key error within ACS's failed logs.
