12-17-2008 03:39 AM - edited 03-10-2019 04:14 PM
I have a issue here on two of my new switches when i telnet i get username and password once logged in then i go to enable mode i again get a username and password prompt this time the password i have to give is enable password.
This is not a issue on other switches on the network pointing to the same server.I have a standard configuration for aaa on the network.
the switches are running 12.2(33)sxh3a
12-22-2008 06:04 AM
This is due to a bug in ACS 4.1
The workaround is to update the ACS.
12-22-2008 10:58 AM
Are you sure its a defect on ACS and not on the device IOS ?
CSCsu21040 : Enable authentication prompts for username/password instead of just pass
Version : 12.2(33)SXH03
Integrated in : 12.2(33.03.12)SXH, 12.2(33)SXH04
Prem
12-23-2008 12:18 AM
My mistake it is the device ios that has the bug and not the ACS.
I think i was in a rush so made a mistake here.
Thanks Prem well spotted.
