AAA TACACS with Brocade Switches
rkallas
We are testing authentication on Brocade switches with our AAA TACACS+ server.  It seems that after authenicating to enable mode, you can type "exit" and be dropped back to level 7 mode.  From this point you can type "enable" and authenticate to the switch using the local "enable" password, not from TACACS.  Has anyone run across this and is there a way to correct it?  Is there something that needs to be configured in TACACS on the server to recognise the Brocade switch and make this work?
Ray
Amjad Abdullah
Hi Ray,
What ACS version you are using?
On a cisco switch the following command is used:
switch(config)# aaa authentication enable default tacacs+ enable
The above command is used to set the TACACS+ as the default check for the enable password. If TACACS+ is not available it will fall back to the local enable password.
You need to look into such option in the Brocade switch.
Amjad
Rating useful replies is more useful than saying "Thank you"
