I am using ACS for Authentication for Access-server. I am using RADIUS for authentication. Now If the user is connected and it has a 1 hours time remaining in his account. Now if this user is authenticate and use the services, and between this if I renew his account and increase the available time from 1 to 60 hours. Now this user autometically disconnected after 1 hour and he has to login back to get his new login creditintial. How can I fix this problem. I dont want to disconnect the user and I want to change his login credentials and It should apply at the same time. How can I fix this problem?
As far as my knowledge goes, if the user is authenticated and using the services, during which you reniew his account, inevitably it has to take effect only during next login. This I believe is a security feature.
Learn, share, save
