07-26-2010 10:39 AM - edited 03-10-2019 05:17 PM
I configured MDA on a 3560 (c3560-ipbasek9-mz.122-53.SE2.bin) with ACS 4.1(1) Build 23 Patch 5 as documented in attached pdf file.
Unfortunately the Cisco IP Phone 7941 authenticates in the DATA domain and not in the VOICE domain.
Does anyone know what's wrong?
Regards, Peter
Solved! Go to Solution.
07-29-2010 05:53 AM
What browser are you using to define the AV Pair on ACS? Please reinput the AV Pair on ACS using Internet Explorer and see if this makes a difference.
--Jesse
07-29-2010 01:15 AM
Some additional info:
Seems my ACS server sends a malformed AVpair back to the switch which it doesn't understand.
RADIUS: Cisco AVpair [1] 40 "device−traffic−class=voice"
This should look like this I think:
RADIUS: Cisco AVpair [1] 28 "device-traffic-class=voice"
Is this a bug in ACS 4.1(1) or maybe in the switch? What can I do?
Best regards,
Peter
07-29-2010 05:53 AM
--Jesse
07-29-2010 06:26 AM
Thanks a lot. As a matter of fact it worked already since I manualy put in the AV pair letter for letter.
So this was a copy paste problem.
Case closed!
