10-14-2010 04:10 AM - edited 03-10-2019 05:29 PM
We have managed to get the above working please find the enlcosed Link for Windows 2003 Certification Authority.
http://www.isaserver.org/img/upl/vpnkitbeta2/pubwebenroll.htm
The problem is that when we revoc the certificate in the revocation list we can not see it in the URL that has been placed in the NCCCA.CRL. it does not seem to load it into the CRL
can you delete all *.CRL files in the CertEnroll and re-Generate them or are the created when you set up the default CA or can you get a default *.CRL and rename it.
10-20-2010 04:07 AM
Hi Dan,
I'm not sure I understood what you're asking.
Is this problem with the Microsoft CA not including the revoked cert info on the CRL file published on the distribution URL.. or is it about ACS failing the revocation check even if a cert IS in the published CRL?
If the problem is with the Microsoft CA.. then maybe some Microsoft expert reading the Cisco Support Community forums may help, but it may be better to look for help also from the Microsoft support.
On the other hand, if I didn't get it and the problem in on the ACS, can you please better explain what happens?
Thanks!
Federico
