03-24-2010 09:25 AM - edited 03-10-2019 05:01 PM
Currently trying to configure 802.1x using PEAP for wireless access. I haven't done this since using ACS 3.3 and I'm lost inregards to the certificate installation and all that good stuff.
The setup is currently working with LEAP and EAP-FAST.
The CA is a Windows 2003 Server.
Thank you,
Ed
04-09-2010 11:36 AM
Are you having problems installing the certificate?
Certificates are installed under System Administration -> Local Server Certificates -> Local Certificates
06-08-2010 04:47 AM
I'm in the same boat, I haven't worked with ACS since verison 3.3, I'm trying to configure PEAP authentication, for our wireless environment.
We are using the ACS platform for both 802.1X, Internal RADIUS and TACACS, both the RADIUS and TACACS authentication are working.
Does any have any good documentation, or links to on the configuring PEAP authentication?
Mike
06-08-2010 05:57 AM
12-03-2010 03:58 PM
Try this, its very useful
http://www.cisco.com/en/US/products/ps10315/products_configuration_example09186a0080b4cdb9.shtml
