01-27-2011 08:01 AM - edited 03-10-2019 05:45 PM
hello,
just a question:
ACS 5.2 running ADE-OS on dedicated 1121.
hostname set as NAME1
"show cdp nei" on switch show weird string, such as "ezdfe...."
Is there a way of forcing cdp announced hostname to match ADE-OS hostname?
TIA
Ivan
01-28-2011 01:45 AM
On the show cdp neigh details you see "ezdfe...." in the hostname or the Device ID field?
Please note that on ACS 5.x the Device ID is not the hostname, and cannot be changed.
HTH,
Tiago
If this helps you and/or answers your question please mark the question as "answered" and/or rate it, so other users can easily find it.
01-28-2011 01:52 AM
you are right: device ID
Device ID: e41f1377b9fa
Entry address(es):
IP address: 10.22.222.252
Platform: CSACS-1121-K9, Capabilities: Host
Interface: GigabitEthernet3/6, Port ID (outgoing port): eth0
Holdtime : 151 sec
Version :
Cisco Application Deployment Engine OS version: 1.2.0.182 Copyright (c) 2010 Cisco Systems.
advertisement version: 2
But due to my dumbness, I'll try one last chance.
Will try to play around w/ BIOS settings, and hopefully get back with a final response.
Thank you for the hint
Ivan
