07-31-2012 06:04 PM - edited 03-10-2019 07:22 PM
Hello
Does anyone have an upto date reference for setting up the ACS v 5.3 for mac filtering via built in radius with wireless lan controllers?
all I seem to find is this old document - which uses the user database.
the ACS 5.3 has host store, which seems like the logical place to setup mac address information
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008084f13b.shtml
Cheers
07-31-2012 06:11 PM
Simon,
Here is the guide on how to configure the mac addresses - http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_system/5.3/user/guide/users_id_stores.html#wp1052914
Basically you can create a service selection rule that will use the internal hosts, and your rule can combine the service-type=call check and network device group = wireless controllers.
Tarik Admani
*Please rate helpful posts*
02-09-2017 04:05 AM
Hello everybody,
i can say i get nearly the same problem. but mine is about filtering mac address connexion from switch port with cisco ACS 5.3 .
i've already configured Device port filtering in the ACS SERVER, but i need help to set mac address filtering.
thank you for helping.
YESHUAWEN
