11-01-2012 08:58 AM - edited 03-10-2019 07:44 PM
Im installing & configuring a new ACS 1121. Ive updated to version 5.3 with patch:
Cisco ACS VERSION INFORMATION
Version : 5.3.0.40.6
Internal Build ID : B.839
Patches :
5-3-0-40-1
5-3-0-40-2
5-3-0-40-3
5-3-0-40-4
5-3-0-40-5
5-3-0-40-6
Two months ago i established a comunication with the Active directory with everything normal. Due to vacations i resumed the configuration today November 1st. And when i tested the Active Directory account, i got clock skew issue, so i checked the NTP settings:
TSJACS-SEDEPP1-01/acsadmin# sh ntp
Primary NTP : 172.24.8.21
synchronised to local net at stratum 11
time correct to within 12 ms
polling server every 1024 s
remote refid st t when poll reach delay offset jitter
*127.127.1.0 LOCAL(0) 10 l 53 64 377 0.000 0.000 0.001
172.24.8.21 .LOCL. 1 u 206 1024 377 0.646 417599. 82.777
Warning: Output results may conflict during periods of changing synchronization.
Since i saw that the clock was behind/ahead aprox 6 minutos. I reconfigured the NTP server by removing and reinserting the command.
And voila:
time correct to within 75 ms
polling server every 64 s
*127.127.1.0 LOCAL(0) 10 l 47 64 177 0.000 0.000 0.001
172.24.8.21 .LOCL. 1 u 46 64 177 0.599 -6.075 23.869
Since the offset was low i tested the Active Directory Connection and it worked just fine. But now i see the offset increasing:
172.24.8.21 .LOCL. 1 u 916 1024 377 0.630 41.429 44.229
172.24.8.21 .LOCL. 1 u 50 1024 377 0.592 202.882 82.799
172.24.8.21 .LOCL. 1 u 952 1024 377 1.077 275.164 72.283
In aprox. 1 hour. This makes me believe that in a month or so ill have Active Directory Issues again.
Is it a bug or maybe a ntp configuration needed. Another interesting point is that i tested NTP with a CISCO CORE switch that was an ntp client to the internet NTP servers, but is currently taking its own clock as reference.
And this is the output:
Primary NTP : 172.24.24.254
time correct to within 11 ms
polling server every 256 s
*127.127.1.0 LOCAL(0) 10 l 7 64 377 0.000 0.000 0.001
172.24.24.254 .INIT. 16 u - 256 0 0.000 0.000 4000.00
This temporarily solves my Active Directory problem but i still would like to have the NTP server pointing to the same reference as the Active Directory.
Ronald.
El mensaje fue editado por: Ronald Lau
11-01-2012 04:40 PM
If you are using windows as your clock source, please use a different source..ie router.
Sent from Cisco Technical Support Android App
