02-12-2019 09:24 AM - edited 03-11-2019 01:55 AM
Hi everyone
I have a installed Cisco ACS 5.8.0.32 with Patch Level 9 and added Patch 10 on a Cisco 1121 Secure.
The patch shows successfully installed an after the reboot. The Patch Level do not match.
sh version
Cisco ACS VERSION INFORMATION
Version : 5.8.0.32.9
Internal Build ID : B.442
Patches :
5-8-0-32-7
5-8-0-32-8
5-8-0-32-9
there shows no Patch 10.
I repeat the Installation
Patch '5-8-0-32-10' is already installed.
% Error: Failure to open / validate the patch
Also i tried to remove the patch bot it also to now work
/admin# acs patch remove 5-8-0-32-10
Note that uninstalling a patch that is not the one most recently installed may cause system instability.
Removing ACS patch requires a restart of ACS services.
Do you want to Continue? (yes/no) yes
5-8-0-32-10 is not the latest patch installed. Please remove the lastest patch 5-8-0-32-9 and try again
/admin#
In other post I view that this issue resolved when you install next patch. But Cumulative Patch 10 is the last patch for version 5.8.0.32
Have any one Information how do solved that issue?
Solved! Go to Solution.
02-12-2019 09:41 AM
02-12-2019 09:41 AM
