Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
796
Highlighted
Beginner
Acs is not receving Tacacs requests from Juniper SSG140
I have configured ACS 5.1 and using Tacacs. I have two juniper SSG140 FW's in different subnet. Tacacs authentication is working on one SSG140 FW, but not on the other one. Tacacs configuration on both FW's are exactly the same. Both FW's have been added in the ACS server with the same shared secret key same profile etc. I don't even see the authentication requests from the FW. ACS can ping both FW's and vice versa. But no joy. Your help will apprecaited.
set auth-server "TACACS" id 1
set auth-server "TACACS" server-name "11.X.1XX.X"
set auth-server "TACACS" account-type admin
set auth-server "TACACS" timeout 15
set auth-server "TACACS" type tacacs
set auth-server "TACACS" tacacs secret "asd234k234l23kSLDF2343423242348SFL=="
set auth-server "TACACS" tacacs port 49
Rgds
2 REPLIES 2
Beginner
Please capture  the traffic b/w sourse and destination ,and check weather TACACS packets are reaching to ACS server or not .If you have 2 ACS servers (Primary & Secondary ) .Try to configure one by one in SSG140 FW's and check .
Beginner
    Thanks for your instructions, I found the issue, which was to replace the command on the SSG140 FW from "admin auth server local" to "admin auth server TACACS".
Thx
