ACS SAN EAP-TLS Issue
we have an issue with eap-tls authentication with SAN (Subject Alternate Name). The authentication uses the CN instead of SAN.
Our enviroment is so build:
1 LWAPP Cisco AP
1 WLC & 1 WCS
1 ACS (4.2.(1) Build 15 Patch 3)
1 CA (Certification Authority enTrust)
1 Windows 8.1 Client
The ACS global authentication configuration is attacched to the discussion.
The ACS certification is loaded correctly and the CA is trusted.
On the client the user certificate is correctly loaded.
In the Failed Attempts I can found in the username field the CN of user's certificate but i cannot see the SAN.
Thanks in advance
Saurav Lodh
Level 7
Level 7
