The ISE 2.5 Beta software is now available! Join the ISE Beta Community to try it in your lab!
177
Beginner
ACS4.1 not responding
hi,
currently i want to authenticate 2960 switch to ACS4.1..(i already tested the configuration in VMWare and is successful)..but on runing environment when i enter the username and password on switch the ACS shows that the authentication is succesful ("Report and activity" button) but the switch is showing failed authentication... i used debug aaa authentication...attached file shows the result of the debug..
Naresh
Highlighted
Beginner
Re: ACS4.1 not responding
i also want to tell that ACS 4.1 is a solution engine, ping is unsuccessful, AP is successfully authenticating the user but switch 2960 fails to authenticate and giving the error mentioned above
Regard
Naresh
Naresh,
Please increase the radius timeout and that should help.
~JG
Do rate helpful posts
Ask the Expert- MPLS troubleshooting
