07-27-2013 03:16 AM - edited 03-10-2019 08:41 PM
Hello
I'm looking to migrate an ACS5.4 config to ISE. Part of the ACS5.4 config involves:
This works fine in ACS but I can't Add/Modify attributes in the ISE System RADIUS IETF dictionary. Is this functionality roadmapped for ISE?
Andy
07-27-2013 05:40 AM
Forgot to mention that I'm currently using ISE 1.1.3. I fround the following in the new ISE 1.2 documentation:
Cisco ISE also creates dictionary defaults for the IETF RADIUS set of attributes that are also a part of
the system-defined dictionaries, which are defined by the Internet Engineering Task Force (IETF). You
can edit all free IETF RADIUS attribute fields except the ID.
I'll upgrade and see if I can edit the attribute that I need.
07-28-2013 10:07 PM
ISE 1.2 can modify the Radius Vendors attributes (add, edit, delete), but can't modify IETF attributes.
I think ISE 1.1.x can do the same thing as ISE 1.2. I will check that tomorrow.
Please rate if this helps
