Anyconnect posture module
munish.dhiman1
HI,
I would like to deploy an Anyconnect posture module with SCCM software distribution. How do i push the posture profile or the config of the posture module?
We can push the software through SCCM and a xml file , however what kind of configuration i need to put in the xml file ? because normally ISE takes care of both installation and profile configuration via CPP .
MD
2 Accepted Solutions
Use the ISE Posture AnyConnect Profile Editor to create the XML configuration file, define the discovery host, server name rules and call home list and other options.
Name the file as ISEPostureCFG.XML and deploy that via SCCM to C:\ProgramData\Cisco\CiscoAnyConnect Secure Mobility Client\ISE Posture folder.
This can happen independent of ISE so its strictly anyconnect question. You might want to post there as well but I googled and found https://www.google.com/search?q=anyconnect+deploy+sccm&oq=anyconnect+deploy+sccm&aqs=chrome..69i57j0l5.5476j1j7&sourceid=chrome&ie=UTF-8
