ASA 5525X AAA login to EXEC mode through ISE
jkuehl
I am using ISE 2.0 and have created a Policy to login to our ASA 5525X running ver 9.5.2 using SSH.
I can login into the ASA to user exec mode, then use enable and type on my password again to get into priv exec mode.
I would like to type in one username and password to get into priv exec mode directly.
This is what I have on our ASA
aaa-server vpnISE protocol radius
 authorize-only
 dynamic-authorization
aaa-server vpnISE (inside) host IP ADDRESS
 key *****
aaa authentication serial console LOCAL
aaa authentication ssh console vpnISE LOCAL
aaa authentication http console LOCAL
aaa authentication enable console vpnISE LOCAL
aaa authorization exec authentication-server auto-enable
I have a Authorization Profile
ASA_Access
Access Type = ACCESS_ACCEPT
cisco-av-pair = shell:priv-lvl=15
The authentication policy is PAP_ASCII for AD and Local
The authorization policy:
nas-port-type: Virtual
network access protocol: Radius
When i attempt to login with this setup it says that password authentication failed.  When i check the Logs i am seeing that i my authentication succeeded.
Am I need to change my attributes to something else to make this work.
Two questions:
1. Have you confirmed that the appropriate rule is now being hit in ISE
2. Are you sending back the correct RADIUS attribute? For ASAs you need to return back:
Radius:Service-Type = Administrative
Thank you for rating helpful posts!
6 Replies 6
nspasov
I have this working fine with my 5506 and ISE. The configs look correct too. When do you get the "password authentication failed" ? Also, can you post some debugs from radius and aaa
when i try and log in the Policy that is being hit is my VPN policy.
This is new after i have completely redone my VPN connection with ISE.
I am working on trying to sort out the Authorization rule now to separate the two.
After moving the Auth rule higher i am able to get the following from debug.
Dec 16 2015 10:52:21 10.10.200.254 : %ASA-6-113004: AAA user authentication Successful : server =  10.10.20.56 : user = jasonkuehl
Dec 16 2015 10:52:21 10.10.200.254 : %ASA-6-113008: AAA transaction status ACCEPT : user = jasonkuehl
Dec 16 2015 10:52:21 10.10.200.254 : %ASA-3-113021: Attempted console login failed user 'jasonkuehl' did NOT have appropriate Admin Rights.
Dec 16 2015 10:52:21 10.10.200.254 : %ASA-6-611102: User authentication failed: IP address: 10.70.24.55, Uname: *****
Two questions:
I was not use that Radius attribute.  I was still using cisco-av-pair = shell:priv-lvl=15.
I have changed to this attribute and everything is working correctly.
Hi Nspasov,
I have the same issue when accessing ASA as admin, i always have to type the enable password to go to exec-mode #
But looking to jkuel config i see he is using Radius and not TACACs for admin access.
Can you please advise how to fix this using TACACS?
