10-06-2015 04:00 AM - edited 03-10-2019 11:07 PM
Hi community,
I was asking myself, can I configure single SSID BYOD Onboarding without SCEP? I'm in this position where I want the users to connect and register their own devices using MSCHAP as inner method but I don't want to provide certificates with SCEP as this is a platform I don't have access to.
It might be losing the whole purpose of BYOD but I just need users to register and de-register their own devices taking the MAC Address administration burden out of IT.
Thanks in advance
Solved! Go to Solution.
10-06-2015 06:44 AM
Hi Antonio,
ISE does support BYOD with EAP-PEAPv0 MSCHAPv2 or EAP-TLS profiles. You can build a supplicant provisioning profile to do only PEAP for the supported platforms (Windows, Android, MacOSX and iOS).
10-06-2015 06:44 AM
Hi Antonio,
10-06-2015 06:06 PM
Thank you Wayne, I will definitely try it out during this week.
11-16-2015 10:03 AM
And to add more to this here is how you do it
11-17-2015 05:42 AM
No access to the blog post, is it just me?
Is it possible to post the pdf?
Cheers
11-17-2015 05:53 AM
Can't access either
11-17-2015 11:15 AM
Check it out now
11-17-2015 05:51 AM
Indeed it worked.
I even took out the whole Google Play procedure by going into Administration -> Settings -> CLient provisioning (left side pane) and changed "Native Supplicant Provisioning Policy Unavailable" to "Allow Network Access"
Didn't know this was possible.
Thank you
