05-20-2015 06:06 AM - edited 03-10-2019 10:44 PM
Hello team,
I face the issue described in the title. In ISE's sponsor portal, when i press print, there is a small bar appear in the screen (probably the preview window) but only the top bar is visible.
I have try all browsers supported (IE 10,11 & Firefox)
Do anyone else face the same issue?
Thanks!!!
Alexandros
05-20-2015 08:30 AM
I am using Firefox 38.01 and I have no issues like you mentioned above on my node.
feel free to rate this post if it helps!
05-26-2015 05:51 AM
Thanks for the reply. I have try with Firefox 38.01 as you suggest but i have the same problem.
I have also try IE11n latest Chrome and Firefox 30 and 38.
Thanks!
06-18-2015 02:56 AM
Hello all,
Thank for your replies. Issue fix after upgrade to version 1.4.
Thanks!
Alex.
05-28-2015 01:33 AM
is the sponsor configured to view guest account details ?
