Cisco ISE 1.3 Sponsors Portal Print not working
Hello team,
I face the issue described in the title. In ISE's sponsor portal, when i press print, there is a small bar appear in the screen (probably the preview window) but only the top bar is visible.
I have try all browsers supported (IE 10,11 & Firefox)
Do anyone else face the same issue?
Thanks!!!
Alexandros
ammahend
I am using Firefox 38.01 and I have no issues like you mentioned above on my node.
feel free to rate this post if it helps!
-hope this helps-
Thanks for the reply. I have try with Firefox 38.01 as you suggest but i have the same problem.
I have also try IE11n latest Chrome and Firefox 30 and 38.
Thanks!
Hello all,
Thank for your replies. Issue fix after upgrade to version 1.4.
Thanks!
Alex.
Venkatesh Attuluri
is the sponsor configured to view guest account details ?
