04-11-2016 10:22 AM - edited 03-10-2019 11:39 PM
I have configured guest type so that we won't have simultanous logins and also guest will only connect from 1 device.
But it is not working well. Attached is the configuation I did.
Can anyone tell me if I did something wrong?
Thanks!
04-11-2016 01:31 PM
Which part is not working? :) From a first look, things look correct.
Thank you for rating helpful posts!
04-12-2016 01:21 AM
From 3 devices, I'm able to login simultanously.
I want to have 1 login on only one device.
If someone try to use the same guest account on another device, ISE will not allow the guest to get access.
Thanks!
