03-16-2018 08:17 AM - edited 02-21-2020 10:49 AM
Hello all.
I have one problem with my ISE 2.3. I have made base configure ISE Posture for anyconnect. I have three authorization profile - Unknown_ users, NON_Compliant_users and Compliant users. If i see that system scan is OK tnen all comliant users get dacl. My question is how can i get different dACL or ACL each user or user group (for example Active Directory Group).
Thank you very much in advance.
Solved! Go to Solution.
03-16-2018 08:29 AM
03-16-2018 08:29 AM
03-20-2018 01:10 AM
RJI thank you very much. I did the same as you said. But I forgot that i need to duplicate other policies to (Non Compliant, unknown) and add it to my domain groups. Now it is working well.
