Highlighted
Beginner
Cisco ISE and ATA 188 profiling.
I have tried to profile cisco ATA 188 adapter, based on cdp attribute;
Platform: Cisco ATA 188
and assigned to a create a same identity group. I am not able to see device profiled according to identity group assigned. Instead of it its always assigned to "cisco - device" group.
On cisco switch side, i am seeing device being in data domain instead of voice domain, but strange enough its getting ip address from voice dhcp pool. If dot1x configs are not applied on port device is getting ip address from voice vlan and working fine.
Any suggestion for this case?
Everyone's tags (4)
3 REPLIES 3
Rising star
are you sure cdp is not
are you sure cdp is not disabled in switch?
Verify the SNMP version
Verify the SNMP version configuration on both Cisco ISE and the switch for
SNMP trap and SNMP server settings
Can you post a screenshot of
Can you post a screenshot of the custom profiling policy that you configured?
Also, what version of code do you run on the switch and ISE
