Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
4217
Highlighted
Beginner
Cisco ISE and authentication for 802.1x printer
Hello
What is the best practice to authenticate a 802.1x printer in Cisco ISE?
The printer can store a certificate for authentication and support EAP-TLS.
Thanks for answer.
Marco
2 ACCEPTED SOLUTIONS
Highlighted
Rising star
Please refer to
Please refer to authentication policies
 www.cisco.com/c/en/us/td/docs/security/ise/1-2/user_guide/ise_user_guide/ise_auth_pol.html#pgfId-1146222
Highlighted
Hi,I use certificates (EAP
I use certificates (EAP-TLS) to authenticate Sharp printers. It seems to work. I havn't heard anything else from the printer guys.
/Philip
6 REPLIES 6
Highlighted
Rising star
Please refer to
Highlighted
Enthusiast
well still MAB is a option
well use MAB  for printers.
Highlighted
/Philip
Highlighted
ISE Deployment Best
ISE Deployment Best Practices
https://www.ciscolive.com/online/connect/sessionDetail.ww?SESSION_ID=4381
Highlighted
EAP-TLS is the way to go. It
EAP-TLS is the way to go. It is way way way more secure than MAB and profiling. However, the question is "How much of a hassle is it going to be to put a certificate on each printer?" Moreover, "What methods do I have (if any) to renew those certificates when they expire?" If have to manually generate a CSR and install a cert on each printer then it can quickly become an administrative overhead nightmare. With that being said, you can use MAB and profiling but just make sure that you lock down the access that those printers get. For instance, do they need access to the internet? Do they need access to anything else but the print server and/or open to all IPs access but only on the printing ports.
I hope this puts you in the right direction!
Thank you for rating helpful posts!
Highlighted
Beginner
I agree with Neno, I would
I agree with Neno, I would suggest MAB with a limited authorization result, only what the printers need to access in the network
